Informações do produto:
● RK3328 CPU with 4-core is rapid and stable, it can give you a high-speed feedback and smooth response
● Optional: 1G RAM + 8G ROM / 2G RAM + 8G ROM / 2G RAM + 16G ROM
● The high-end version ( 2G RAM + 16G ROM ) has gigabit interfaces, with dual-band 2.4G + 5.8G WiFi and Bluetooth 4.0
● New Android 7.1 version provides you the benefit of using all the latest updates and having access to all the tools, games, and Apps at the play store smoothly
● Supports 4K x 2K video, gives you high-quality video experience
● Support full video format decoding. Support H.265 hardware decoding. H.265 and H.264 decoding will offer you high definition pictures and movies
Link do produto: https://goo.gl/w7yGM9
