Informações do produto:
Combines durable 1.5GHz ARM Cortex – A53 CPU with Amlogic S912 chip
Android 7.1 version, coupled with the rapid and stable configuration
4K / 3D video gives you high-quality video experience
Dual-band WiFi gives you more smooth speed experience
Bluetooth 4.1 connectivity. Easy pairing with most Bluetooth-enabled devices
Support Miracast / DLNA / Airplay, share your video to your TV
The remote control is powered by 2 x AAA battery ( not included )
Código de desconto: PTBRMAR52
Link do produto: https://goo.gl/VzegV6
