Informações do produto:
Original Xiaomi xiaofang smart 1080P IP camera for home security
1080P full high definition resolution provides a clear image
1/2.7 inch CMOS sensor and 8X digital zoom, bring more details
F2.0 aperture, 110 degree super wide angle FOV
IR-cut, support day and night auto switch
Built-in 2pcs 850nm LEDs, support night vision range up to 9m. You can have a clear view even in a dark environment
Support motion and sound detection, detects the smoke and CO alarm, send you the alarm when it is triggered
Two-way audio, you can talk to your family when you are not at home
Max support 64G extended TF card ( not included )
Magnetic bracket, it can be mounted on any metal surface
Support time-lapse recording
Please download APP "Mi Home" from Apple Store or Google Play
Support Android 4.0 and above, iOS 7.0 and above system devices
Código de desconto: FELIZNATAL53
Link do produto: https://www.gearbest.com/ip-cameras/pp_620813.html
