Um novo aparelho de custo barato!
DOOGEE Y100 Pro 5" OGS MTK6735 Quad-Core 64-bit Android 5.1 4G LTE Phone 13MP CAM 2GB RAM 16GB ROM OTG OTA
Preto:http://www.tinydeal.com/pt/doogee-y1...-p-151474.html
Tamanho da tela: 5.0"
OS: Android 5.1, Supports OTA Upgrade
Estilo: Tela de Toque Celular
Marca: DOOGEE
Processor Cores: Quad-Core, 64-bit
CPU Models: MTK6735
CPU Frequência: 1.3GHz
GPU: Mali-T760
Material de Shell: Metal
Cor: Cinzento
ROM: 16GB
RAM: 2GB
4G: FDD-LTE, 800MHz, 1800MHz, 2100MHz, 2600MHz
3G: WCDMA 850MHz, WCDMA 1900MHz, WCDMA 2100MHz
2G: GSM 850MHz, GSM 900MHz, GSM 1800MHz, GSM 1900MHz
Tipo de Tela: HD, IPS, OGS Full-Lamination, 720P, Tela de Toque, Capacitiva
Resolução da Tela: 1280 x 720 pixels
Material da Tela: Gorilla Glass, 2.5D Screeen
Multi-toque: Multi-touch
Bateria: 2200mAh, Uma Bateria
Desbloqueado: Sim
Screen Lock: Slide, Pattern Unlock, PIN Unlock, Password
Espera: 2 SIM 2 Espera
SIM Cartão: Norma Cartão SIM, Micro SIM Card
Transferência de Dados: LTE, GPRS, EDGE, HSPA, HSPA+
